Jedi_Knight
Jan 24, 2005Tutor
Discovering your ReadyNAS without RAIDar
RAIDar is the discovery agent program used to setup/detect your ReadyNAS in the Windows/Mac environment. In the absense of the RAIDar software, or using any UNIX OS including LINUX, you can use the f...
objective
May 01, 2009Aspirant
Hi Jedi Knight
Is there a way of by-passing the usual GUI for the ReadyNAS Duo - I'm finding setting up backups incredibly slow and hitting right issues with some share volumes.
A terminal session into the Duo ?
Paul
Paul
