PeterDorr
Jan 15, 2012Aspirant
Disk attempted to add is too small with an Identical disk??
I had an HD crash of one of my Seagate ST31500341AS 1397 GB on my ReadyNAS Pro with RAID Level X-RAID2, 6 disks (with dual redundancy) I had already ordered an extra disk when I put the NAS together ...
PeterDorr
UPDATE: just took out the 5 disks, but it failed to recognise the one disk because it cannot mount the Raid it says.
Did a check with RAIDar and that gave me the message that the root is corrupt.
So I will indeed hook it up to a windows machine and remove all partitions if any
