alan27
Oct 29, 2011Aspirant
Disk drive diagnostic tool are they definitive ?
Hi All Can anyone let me know if the disk drive diagnostic tools are definitive. If I run the Western Digital Data LifeGuard Diagnostics tool on my 4 x 2Tb WD-20EARS CAVIAR GREEN 2TB 64MB 7200 SA...
alan27
Oct 31, 2011Aspirant
Hi Mdgm
Thanks again, for taking the time to look and help, yes your right , it came with 4.1.6, last Dec then upgrade 2 ish month after that to 4.1.7 . cool so there looking good at the mo :-)
Here is my Partition.log
What can you tell from that then ? (hope all is good there also)
Disk /dev/hdi doesn't contain a valid partition table
Disk /dev/hdc: 2000.3 GB, 2000388448256 bytes
255 heads, 63 sectors/track, 243200 cylinders, total 3907008688 sectors
Units = sectors of 1 * 512 = 512 bytes
Disk identifier: 0x00000000
Device Boot Start End Blocks Id System
/dev/hdc1 2 4096001 2048000 83 Linux
Partition 1 does not end on cylinder boundary.
/dev/hdc2 4096002 4608001 256000 82 Linux swap / Solaris
Partition 2 does not end on cylinder boundary.
/dev/hdc3 4608002 3906992305 1951192152 5 Extended
/dev/hdc5 4608003 3906992305 1951192151+ 8e Linux LVM
Disk /dev/hde: 2000.3 GB, 2000388448256 bytes
/dev/hde1 2 4096001 2048000 83 Linux
/dev/hde2 4096002 4608001 256000 82 Linux swap / Solaris
/dev/hde3 4608002 3906992305 1951192152 5 Extended
/dev/hde5 4608003 3906992305 1951192151+ 8e Linux LVM
Disk /dev/hdg: 2000.3 GB, 2000388448256 bytes
/dev/hdg1 2 4096001 2048000 83 Linux
/dev/hdg2 4096002 4608001 256000 82 Linux swap / Solaris
/dev/hdg3 4608002 3906992305 1951192152 5 Extended
/dev/hdg5 4608003 3906992305 1951192151+ 8e Linux LVM
Disk /dev/hdi: 2000.3 GB, 2000388448256 bytes
