alan27
Oct 29, 2011Aspirant
Disk drive diagnostic tool are they definitive ?
Hi All
Can anyone let me know if the disk drive diagnostic tools are definitive. If I run the Western Digital Data LifeGuard Diagnostics tool on my 4 x 2Tb WD-20EARS CAVIAR GREEN 2TB 64MB 7200 SAT and they all came back as passed, can I yes 100% that the disk are ok ?
Or is there a possibly they could still be bad ?
Thanks
Alan
Thanks
Alan
- alan27AspirantNow you mention it , it’s not the quickest no , that was something I was planning to look into later, do you know how I can fix this and align the sectors ? I’m guessing it’s a factory reset using 4.1.7 or 4.1.8 ?
- mdgm-ntgrNETGEAR Employee RetiredYes, upgrading to 4.1.7 or later (you've already done this), verifying update is successful (i.e. new version shown in Frontview and/or RAIDar), a backup and a factory reset is the way to fix it.
Of course there are other performance tweaks you can make too. See ReadyNAS Performance Expectations - alan27Aspirantyour a star thanks for your help mdgm , will do that :-)
- PapaBear1Apprenticealan27 - one never really knows when a drive may fail. You may not experience a failure in drives 2-4 for a long time. When I set up my NV+ over 4 1/2 years ago with two 500GB Seagates, one failed in a little over a month. The second one was still going strong when I upgraded the drive size last summer and it had over 25,600 hours on the drive. Hopefully you will not have another drive failure for some time, but one just never knows.
- alan27AspirantThanks for the advice guys. I know where I stand now on this, I guess the best thing to do is make sure you have a good backup ;-)
