Han_Solo
Jan 10, 2006Tutor
Disk Drive Test Utility Tool links
Here are some links to disk drive diagnostic tools offered by different drive manufactures. Some of the links are for a specific line of drives but will give you the general idea of what test are ava...
bhoar
Jul 15, 2006Aspirant
b-a-t-m-a-n wrote: Hi bhoar,
Is there a particular utility you used to make your USB Key bootable?
Yeah, argh, it's been a while. Let me search...
The file you need is from HP and is called: sp27213.exe
Unfortunately, I can't seem to find it on the HP site, so you will need to google or search HP for it.
This site says it might have it but I'm not sure they have permission to post it: http://www.bay-wolf.com/usbmemstick.htm
-brendan
