Han_Solo
Jan 10, 2006Tutor
Disk Drive Test Utility Tool links
Here are some links to disk drive diagnostic tools offered by different drive manufactures. Some of the links are for a specific line of drives but will give you the general idea of what test are ava...
bte4
Jun 29, 2008Aspirant
I think I know the answer to this, but I just want to make sure. In order to use one of these tools to test the drives, one has to physically pull the drive from the unit and test directly in a PC. Is that correct, or is it possible to test directly in the ReadyNAS Duo? The reason I ask is that when I put the 2nd 500GB drive in the Duo, I heard some clicking noises when the drive was being accessed. I don't see anything on its status in Frontview that would indicate cause for concern. But I would feel better if I could test the drives. Any advice? Thanks in advance.
