Han_Solo
Jan 10, 2006Tutor
Disk Drive Test Utility Tool links
Here are some links to disk drive diagnostic tools offered by different drive manufactures. Some of the links are for a specific line of drives but will give you the general idea of what test are available.
These tools are helpful in clearing out all info on a drive and fixing minor problems with drives. Some of the manufactures recommend that you run there test utility before they will issue an RMA. The tools are easy to use but can take up to a couple of hours to complete depending on the test you select.
Most of these tools are windows based but I think I saw some that support Linux. They can also run off a boot disk or some will run on your desktop.
Hitachi Drive Fitness Test
Maxtor PowerMax
Seagate Sea tools
WD Data Lifeguard Diagnostic for Windows
Maxtor PowerMax
Seagate Sea tools
- LavigneAspirantMagican can check multiple external disk usage.
http://www.magicansoft.com/magican.html
