mitip
Nov 18, 2012Follower
disk fail with new firmware
I now have a bricked Duo after it did a firmware upgrade on its own. N The net result is that I now have five perfectly good hard drives, all out of warranty, not ones in 'the list' because i bough...
Nov 19, 2012Guru - Experienced User
Erase the partitions on one of the hard drives on you PC (Windows Disk Manager can delete them). Then put the disk into the duo (powered down, by itself), and then start it up. I expect that the Duo will re-install the OS and recreate an empty C volume.
mitip wrote: Any prompts on how to go back a firmware step given the stae of the my Duo?
