PMO-Milan
Sep 12, 2016Aspirant
Disk format compatibility
Hello, I own a RadyNAS Ultra 2 which suddanly stopped switching on. I am now ready to purchase a newer model but I also need to find a way to recover the disks content.
My question is which one of the more updated models I can purchase into which I can install the existing disks keeping the access to the saved data. I imagine I need to stay with an R4 version, but if I could get an R6 version it will be preferable.
As an added information, I tried using LinuxReader on Windows to recover the data and I can see the shared folders with the proper name but at 0 size and as unknown type.
Thank you in advance for your support.
Paolo
- mdgm-ntgrNETGEAR Employee Retired
You would need an x86 unit. See http://kb.netgear.com/app/answers/detail/a_id/29875/~/readynas%3A-migrating-disks-from-raidiator-to-os-6
We've just released the RN526X and RN626X, two new x86 models which would also work.
You would also need somewhere to backup your data to.
- PMO-MilanAspirant
Thank you for your clarification.
In relation to the data backup, as I mentioned I tried to access the data using Linux Reader on a Windows PC but it shows the shared folder as empty/unknown file types. Any suggestion?
Thanks,
Paolo- mdgm-ntgrNETGEAR Employee Retired
It would need to support mdadm RAID, lvm2 and EXT4.
Why not just use a Linux machine?
