WillisComputing
May 25, 2021Follower
Disk is not sighed by netgear
I purchased several spare netgear drives to work in either my ReadyData 516 or Ready NAS 4200. I need to make sure that they are all signed. I inserted a new one to replace a failed drive and it r...
mdgm
May 25, 2021Virtuoso
Which version of ReadyDATA OS are you running? ReadyDATA OS 1.4.5 doesn't required signed disks. If you are still having problems on ReadyDATA OS 1.4.5 then I assume you would need help from NETGEAR to sign the disks assuming they are disks bought from NETGEAR.
The ReadyNAS 4200 runs RAIDiator-x86 4.2.x and doesn't require signed disks. Only the ReadyDATA requires signed disks. Do you mean ReadyDATA 5200?
