linusdunkers's avatar
linusdunkers
Disk Spin Down power management settings
On the page "Just released – RAIDiator 5.3.5 (ARM)" (http://www.readynas.com/?p=6412) from May 24 2012, you will find this in the release notes:
The following are changes since RAIDiator 5.3.4:
New features and bug fixes
8. Allow user to customize Disk Spin Down power management settings.
Is this the solution that Netgear came up with to solve the Disk Spin Up problem?
The issue was that the disk took a bit too long to spin up and was marked as broken causing a very long raid rebuild upon next reboot.
I had terrible problems with this and was just about to return my ReadyNAS NV+ v2 when the update (5.3.5) was released.
This update solved my problems but it took a while to understand how it was solved...
The simple but not very sexy solution from Netgear was to by default disable disk spin down!
And I have so far left this setting in default mode since I guess the actual problem is not solved? Or?
The result is that that my 8 Seagate (ST3000DM001-9YN166) disks (2 x ReadyNas 4 disks Raid 5) are constantly spinned up and using more power than necessary and causing more heat = higher fan speed = more sound than necessary. Therefore I once again ask, is this the best solution Netgear could come up with?
  • StephenB's avatar
    PapaBear wrote:
    StephenB - I had more reference as to whether to shut down desktops at the end of the day and then cold boot the next morning as opposed to leaving them on overnight and letting the machine sleep. At one point at work there was so much stuff loading at boot that even on C2D desktops it took several minutes to boot. You could literally hit the power button, go get a cup of coffee and come back and still wait for the log on screen. In this situation, most users chose to leave them one overnight as it was just a few seconds for the PC to "wake up".
    Yes.
    I think there are four basic themes in the various posts on this particular topic:
    (1) the potential impact of disk spin down on reliability/disk life. As far as I can see there is not a lot of data out there. But from what I have seen, I think it is prudent to set your spin-down threshold conservatively.
    (2) the potential impact of disk spin down on NAS usability. That is what your example illustrates. Waiting for spin-up can be frustrating, and some devices and applications don't behave well when there is a spin-up delay. If I had one of those devices I would leave my disks spinning.
    (3) Some users are more concerned about reducing their carbon footprint than the economics. Some of them are willing to invest a lot of time trying to sort out why their drives won't spin down as expected.
    (4) Some users want to reduce acoustic noise from the NAS when it isn't in active use. Like the "green" users, some of them are willing to invest a lot of time trying to sort out why their drives won't spin down as expected.
  • HERBIEO wrote:
    KNOWN BUGS AND LIMITATIONS
    Journaling filesystems like ext3, reiserfs or xfs bypass the kernel's delayed write mechanisms. This amounts to lousy spindown times when working off such a partition. There's no workaround for this.
    It seems to me that I found even scarier disclaimers in the noflushd docs than this, though I can't put my finger on the text atm. Suffice to say my own troubles with noflushd led me to avoid using spindown altogether.
    Back off-topic :oops: regarding fluorescent lamps and PCs left ON 24/7, there's another angle on this that has to be accounted for in a commercial environment, which is not just energy usage but also energy usage. :wink: Namely that watts consumed also directly translates to BTUs produced into the space. The biggest heat producer in a commercial office building is the occupants, and next biggest is the lights! Not sure where computers are, but maybe these days a strong 3rd. Anyway you don't wanna have to cool-down the hot air produced by light fixtures 24/7 if occupancy is only e.g. 12/5. So you turn 'em off. Cooling is expensive, very expensive.
    For those offices where the PCs take too long to boot, I'd be inclined to try Hibernation mode to see if that's an acceptable alternative to the users.
  • Maxblack - even more expensive is the replacement tubes and the union electricians wages to come and change them out periodically. In a large industrial plant setting that drives many more decisions than the cost of anything else.
  • StephenB's avatar
    Not sure what implication you are drawing. however it is true that the cost of "relamping" is what is balanced against the cost of energy use. The US government advice says that if you won't be using the fluorescent lights for 15 minutes you should turn them off. (http://www.energysavers.gov/your_home/l ... opic=12280).
    Anyway, our facilities have corridor lights on timers, and a couple years ago replaced the switches with motion-sensor versions that automatically turn off the lights in the offices if no motion has been detected for a while. So at least in our company there is no debate on turning off the lights.
    The corresponding tradeoff for a NAS is balancing the power savings against the disk replacement costs. I haven't seen much definitive on this topic, though there are several researchers who have been looking at variations of Raid that allow some disks to spin down. For instance, concentrating frequently accessed data onto some of the disks can allow the other disks to spin down. One paper on this is here: http://www.eng.auburn.edu/~xqin/pubs/icpp10.pdf It is a bit surprising that there is so little information on what is suitable spin down threshold.
ProSupport for Business
