HenrihasaNas's avatar
Aug 22, 2024
Disk Test Status
Hi, I have started a disk test on my Readynas 626x. It has 6 drives of 6 TB each in X-raid. There is about 4TB of free space left. I have been having issues with small files corrupting on the NAS. ...
  • StephenB's avatar
    Aug 22, 2024
    HenrihasaNas wrote:
    But where do I see the progress?
    I dowloaded the logs and saw in the volumes file that 4/6 disk have passed their latest test, the first 2 disk are running the test. It has been over 48 hours since I started it. Anyway to get an indication how long this might last?
    The web ui doesn't give progress.  You can get some idea with ssh, using smartctl -a /dev/sdX (using the appropriate drive letter for the disk you want to get the status for).
    Every sector of every drive in the volume is read, so it does take a while. And if a disk isn't healthy, it will take longer...
    What model disks are you using?
    Have you looked in the logs for disk errors?
ProSupport for Business
