HenrihasaNas
Aug 22, 2024Tutor
Disk Test Status
Hi, I have started a disk test on my Readynas 626x. It has 6 drives of 6 TB each in X-raid. There is about 4TB of free space left. I have been having issues with small files corrupting on the NAS. ...
- Aug 22, 2024
HenrihasaNas wrote:
But where do I see the progress?
I dowloaded the logs and saw in the volumes file that 4/6 disk have passed their latest test, the first 2 disk are running the test. It has been over 48 hours since I started it. Anyway to get an indication how long this might last?The web ui doesn't give progress. You can get some idea with ssh, using smartctl -a /dev/sdX (using the appropriate drive letter for the disk you want to get the status for).
Every sector of every drive in the volume is read, so it does take a while. And if a disk isn't healthy, it will take longer...
What model disks are you using?
Have you looked in the logs for disk errors?
HenrihasaNas
Aug 22, 2024Tutor
Thanks,
The drives are WD blue drives (so not specifically designed for NAS)
No, I haven't had disk error messages and can't see anything out of the ordinary in the logs.
From the smart check I see that One drive has a ridicioulously high load cycle count (>1.000.000), but that one actually passed the disk test.
The tow drives that are still running the test (A and B) show status 241 - 10% of test remaining.
I will check again in about 12 hours.
Sandshark
Aug 23, 2024Sensei
"WD Blue" is not a model number, but most likely those are SMR drives unless they are quite old, which will definitely give you issues with RAID. Writes can also be excessively long for large files or a whole lot of small ones, but the reads for the drive test aren't really affected. If you give a specific model number, we can check if they are SMR (bad for RAID) or CMR (good for RAID), or just Google the model number and "SMR"
- HenrihasaNasAug 23, 2024Tutor
WD60EDAZ, so SMR
- StephenBAug 23, 2024Guru - Experienced User
HenrihasaNas wrote:
WD60EDAZ, so SMR
Not a good choice for ReadyNAS, particularly with OS-6 systems.
But the performance issues with SMR are related to writes, not reads. If you are writing files to the NAS while the disk tests are running, that could be a factor in the running time.
- HenrihasaNasAug 23, 2024TutorNo, I had issues writing small files. That was the reason I started the disk test.
It is still stuck at 10%, so now I have rebooted the nas and via ssh started a long disk test for just one disk. Should be finished in 12 hours or so.
