alisys
Nov 14, 2017Aspirant
Disks compatibility for RN1100
Hi, We need to replace the disks from RN1100. I can not find the NAS in the compatibility list. Where can I find it? Can you recommend 2TB discs approximately? Thanks!
- Nov 14, 2017
It is there (select "legacy", then Readynas 1100). But it's a waste of time to use it - the HCL hasn't been updated for years, and many of the disks are long obsolete.
WDC Red or Seagate Ironwolf are reasonable choices, given the relatively low performance of the 1100. If you prefer enterprise class, then perhaps use WDC Red Pro or Seagate Ironwolf Pro. I don't recommend desktop drives (even if they are on the HCL) - nas-purposed drives are similar in price and are better choices.
Nov 14, 2017Guru - Experienced User
alisys
Nov 15, 2017Aspirant
Thanks!
