gzjeffrey
Jan 28, 2019Aspirant
Dose the ReadyNAS NV+ v2's single core CPU powerful enough for 4K Vedio streaming?
I'm planning to buy a secondhand ReadyNAS NV+ v2 at a very low price. Considering that this is an older model, I wonder if its single-core CPU will work well for heavy load as 4K video streaming s...
- Jan 28, 2019
In short: very bad idea. The NV+ V2 is not powerful enough and it's outdated operating system is not going to allow you to run the latest application for transcoding. They can still make a good simple file server, including a backup to a newer, more powerful NAS used for transcoding. Or, you can run the transcoding app on a PC and just use the NAS for storage of the video files.
Jan 28, 2019Guru - Experienced User
One warning here - a lot of NV+ v1 owners mistakenly think they have a v2. The labels are a bit confusing.
An NV+ v1
- runs 4.1.x firmware
- says NV+ on the front panel
- might say v2 or v3 on the label on the bottom or back.
- uses a sparc CPU
An NV+ v2
- runs 5.3.x firmware
- says NV+ v2 on the front chassis
- uses an arm CPU
Netgear stopping shipping the NV+ v1 in 2011; they stopped shipping the NV+ v2 in 2013.
Both models use SMB 1.0, so if you are running Windows 10 you will need to make sure the SMB 1.0 client is installed on the PCs.
gzjeffrey wrote:
I wonder if its single-core CPU will work well for heavy load as 4K video streaming service?
4K streaming rates (from Netflix or Amazon) are about 15-25 mbps (2-3 MB/sec). 4K BluRay is no more than 128 mbps (16 MB/sec). An NV+ v2 can deliver about 60 MB/sec, so it can easily stream 4K.
However, the NV+ v2 can't transcode in real time (and new ReadyNAS can't transcode 4K in real-time either). So your players will need to support the formats - generally HEVC for video, and dts, dolby digital (ac3), or aac (mp4) for audio. Plus your network will need to carry the traffic - not difficult for gigabit ethernet, but the BluRay rates could be a challenge for your wifi.
Also your options for the streaming server are limited. In particular, Plex stopped support for the NV+ v2 some years ago.
Although I've never owned an NV+ v2, in my opinion the software never became fully mature. So you should review the software manual, and make sure it has what you need. http://www.downloads.netgear.com/files/GDC/READYNAS%20ARM-PLATFORM%20(DUO%20V2,%20NV+%20V2)/RAIDiator%205.3%20SW%20Manual_5Sep12.pdf
gzjeffrey
Jan 31, 2019Aspirant
thanks a lot!
