ProsperoParisi
Dec 31, 2016Follower
Double raid1
Hi, I have 4 hard drives and a readynas rn31400, you can make 2 raid1? HD1+HD2= raid1-1 and hd3+hd4=raid1-2? Thank you
Dec 31, 2016Guru - Experienced User
Thank you
Yes. You'd switch to flexraid after the initial setup, and destroy the RAID-5 (xraid) volume. There's no need to wait for the volume sync to complete.
Then you can select the first two drives, and create a RAID-1 volume; and repeat that process with the second two drives.
I suggest that you read through chapter 2 in the software manual first - http://www.downloads.netgear.com/files/GDC/READYNAS-100/READYNAS_OS_6_SM_EN.pdf
aalexandrebeta
Feb 17, 2017Master
I do have 3 raid 1 array with no issues!!
