ProsperoParisi
Dec 31, 2016Follower
Double raid1
Hi, I have 4 hard drives and a readynas rn31400, you can make 2 raid1? HD1+HD2= raid1-1 and hd3+hd4=raid1-2? Thank you
Dec 31, 2016Guru - Experienced User
Thank you
Yes. You'd switch to flexraid after the initial setup, and destroy the RAID-5 (xraid) volume. There's no need to wait for the volume sync to complete.
Then you can select the first two drives, and create a RAID-1 volume; and repeat that process with the second two drives.
I suggest that you read through chapter 2 in the software manual first - http://www.downloads.netgear.com/files/GDC/READYNAS-100/READYNAS_OS_6_SM_EN.pdf
cpu8088
Feb 17, 2017Virtuoso
2 x raid 1 that would be 2 volumes/arrays of raid 1
how about raid 10?
- aalexandrebetaFeb 18, 2017Master
Raid 10 is not easy to manage and you are less flexible!
- StephenBFeb 18, 2017Guru - Experienced User
how about raid 10?
Yes, that would be another option.
Raid 1 is good Raid 5 better and 6 ideal!
Lots of enterprises run RAID-10. Protection is in between RAID-5 and RAID-6, and speeds are usually better than RAID-5.
