funglenn's avatar
funglenn
Luminary
May 03, 2020
Downgrading Readynas from OS 6.10 to 6.9.x
The title says it all. I upgraded and now I cannot compile virtualbox 5.1 using the linux linux-4.4.190-x86_64 kernel.     I know the postings say do not, but is there anyway to go back in conjunct...
  • Sandshark's avatar
    Sandshark
    May 03, 2020
    Thanks.
    For anyone else contemplating the same thing:
    I just tested this on a virtual NAS.  It is not necessary to modify the time.  Instead of modifying the length, delete one byte after the header to make up for the one added in the header.  To verify everything is aligned, go to 0x4000 and verify that the ASCII data csums.md5 starts exactly at 0x4000.
    I called the "update" 6.10.8.  The file name doesn't matter, BTW, just how it identifies itself in the file header.
    I did not see any immediate issues with access, but funglenn did see Samba issues, so consider that this downgrade may cause you to have to factory default to fix issues caused by downgrading Samba, and act accordingly.
ProSupport for Business
