xushi
Mar 03, 2017Aspirant
DRAM Test Fail A0000000 - RAM or other fault?
Hi all, I would like to ask you for advice, as I've had very successful and excellent support from the community before :) I finally bought a backup 8Tb disk to backup my ReadyNAS NV+ (the old v1...
- Mar 04, 2017
It's not a code, it's the address. It most likely is a DRAM and the only way to know for sure is to swap it out and re-test.
Sandshark
Mar 04, 2017Sensei
xushi
Mar 05, 2017Aspirant
Ah, interesting address.
Cheers. I'll order a Crucial one as it's in their supported list. I'll keep this thread open for now so I can update it with the solution.
- mdgm-ntgrMar 05, 2017NETGEAR Employee Retired
Have you tried reseating the RAM.
Note the NV+ can be very picky as to which memory will work. We found some RAM sticks on the compatiblity list had newer revs with the same part number that were incompatible. It was this that led us to discontinue the memory compatibility list. We can't test every rev of a 3rd party memory module to see if they might have broken compatibility.- xushiMar 05, 2017Aspirant
I didn't reseat it, but will try that tonight.
I recall buying the same type/make for the second NV+ I have which is working fine. Also, the current one was working fine until now.
I may start backing up the working NAS and try its RAM stick onto the non working one as a quick test too.
Thanks for the suggestion.
