xushi
Mar 03, 2017Aspirant
DRAM Test Fail A0000000 - RAM or other fault?
Hi all, I would like to ask you for advice, as I've had very successful and excellent support from the community before :) I finally bought a backup 8Tb disk to backup my ReadyNAS NV+ (the old v1...
- Mar 04, 2017
It's not a code, it's the address. It most likely is a DRAM and the only way to know for sure is to swap it out and re-test.
Sandshark
Mar 04, 2017Sensei
xushi
Mar 17, 2017Aspirant
Thank you all so much for your help!
Yep, I tried reseating the ram and testing, but it failed again around the 1st / 2nd tests with a different address.
I just swapped it with another Crucial, ran a full RAM test which is successful, and it's up and running again!
This community is one of the best I've had experience with.
Faulty RAM:
New one, ~$13 from Amazon:
