AMRivlin
Jan 30, 2012Apprentice
Drive Compatibility List - Updated Often?
I just purchased a Pro 6. I am considering purchasing 3 2TB WD20EARX. This drive is listed compatible for some ReadyNAS, but NOT the Pro6. Is it possible the list is out of date? WD20EARS IS lis...
mdgm-ntgr
Jan 30, 2012NETGEAR Employee Retired
AMRivlin wrote: Is it possible the list is out of date?
No, the ReadyNAS models for which the WD20EARX is on the compatibility list are very different to the Pro 6. Stick to the compatibility list.
AMRivlin wrote:
WD20EARS IS listed for the Pro6, what differs between S and X?
I'm not sure, but I do know that the drives are different. Support will be denied if you use disks outside the compatibility list.
AMRivlin wrote:
My decision for the WD20EARX is based solely on price $129 per drive. Is there a better drive to select in that price bracket?
Maybe look at Hitachi or Samsung
