boblam
May 03, 2012Aspirant
Drive Firmware Update Process for ReadyNAS
I have a ReadyNAS Ultra 4 Plus device. I just put in four Seagate - Barracuda LP ST2000DL003 - 2 TB drives. I found out that there is a issue with these drives (http://www.readynas.com/forum/viewtop...
May 04, 2012Guru - Experienced User
You can combine an eSATA->SATA cable with an inexpensive SATA/IDE -> USB converter kit. The kit usually includes a power brick with a SATA power connector, which can be used separately.
I've used this approach quite successfully when testing both WD and Seagate drives.
