munka
Aug 31, 2012Aspirant
Drive OK after high Reallocated Sector Count
Hi. Have two ReadyNas Duos - one for home (with 2TB drives, Raidar 4.1.7), one for work (with 1.5TB drives, Raidar 4.1.8)). I got a sudden reallocated sector count failure on one of the 2TB drives. ...
Sep 01, 2012Guru - Experienced User
I'd check on the Seagate site to see if it is still under warranty. If so, I'd RMA it (using failure code 659DC7AE. See http://www.seagate.com/staticfiles/supp ... codes.html)
mdgm wrote: The disk is failing. I wouldn't trust it.
I certainly wouldn't use it, except perhaps as a doorstop.
