drewe2000
Nov 07, 2012Aspirant
Drive or ReadyNAS failure? I can't decipher alert...
I've had this ReadyNAS NV+ a long time, and this one has given me no trouble until now. I'm receiving email alerts "Access to the disk on channel (??) is producing I/O errors. Although the array i...
mdgm-ntgr
Nov 07, 2012NETGEAR Employee Retired
Probably /dev/hdg is the culprit looking at the current pending sector count.
Your disks are not on the compatibility list. Also the Load Cycle Count on your disks is pretty high.
I'd suggest you power down your NAS, remove disks (label order), connect them up to a SATA port in your PC and check them using WD Lifeguard Diagnostics.
