glamisman
Mar 03, 2015Aspirant
Drive size didn't change after removing 30gb?
I have removed over 30 gb on my nas drive and it still shows the same amount of space after that, I have rebooted and checked the recycle bin and it didn't have anything in it, I would think if you re...
RX
Mar 03, 2015Luminary
Is your NAS a Duo v1 or Duo v2? Kindly check this link: http://www.rnasguide.com/2012/01/09/how ... -or-nv-v2/
What is the current FW version of your NAS?
Have you tried to reboot your NAS?
Is your NAS set on XRAID?
