glamisman
Mar 03, 2015Aspirant
Drive size didn't change after removing 30gb?
I have removed over 30 gb on my nas drive and it still shows the same amount of space after that, I have rebooted and checked the recycle bin and it didn't have anything in it, I would think if you re...
glamisman
Thanks for the reply's, I believe from the pictures it is a V2,I have rebooted the drive, it is set to XRAID and I have updated the firmware, but I will check the version when I get home, how to you disable the recycle bin.
Thanks
Thanks
