glamisman
Mar 03, 2015Aspirant
Drive size didn't change after removing 30gb?
I have removed over 30 gb on my nas drive and it still shows the same amount of space after that, I have rebooted and checked the recycle bin and it didn't have anything in it, I would think if you re...
Nhellie
Mar 03, 2015Virtuoso
this is for v1 so we need to know the correct version of the NAS.
Log in to the NAS Frontview.
Click Shares > Share list. This brings up a list of your shares.
Click the pen and paper icon under CIFS for the share you want to enable the recycle bin for.
Scroll down to Recycle Bin and unselect the checkbox Enable Recycle Bin. (this is where you can also adjust the settings for when the files should be automatically deleted and the size limit.)
Click Apply in the lower right corner.
