glamisman
Mar 03, 2015Aspirant
Drive size didn't change after removing 30gb?
I have removed over 30 gb on my nas drive and it still shows the same amount of space after that, I have rebooted and checked the recycle bin and it didn't have anything in it, I would think if you re...
mdgm-ntgr
Mar 03, 2015NETGEAR Employee Retired
Ah, then you need to delete some snapshots of the share in question to free up the space.
