glamisman
Mar 03, 2015Aspirant
Drive size didn't change after removing 30gb?
I have removed over 30 gb on my nas drive and it still shows the same amount of space after that, I have rebooted and checked the recycle bin and it didn't have anything in it, I would think if you re...
glamisman
How do you remove snapshots, I see that there are 40 (10 months protection), but when I select the share and select snapshot it asks new snapshot name.
Thanks
Thanks
