glamisman
Mar 03, 2015Aspirant
Drive size didn't change after removing 30gb?
I have removed over 30 gb on my nas drive and it still shows the same amount of space after that, I have rebooted and checked the recycle bin and it didn't have anything in it, I would think if you re...
vandermerwe
Mar 04, 2015Master
Snapshot will create a new manual snapshot.
You need to click on Shares, then the share in which you want to remove snapshots, then click on recover.
You can then select the view the suits you best. You will be able to view the sanpshots.
Click on the one you want to delete and select Delete.
