kylepaddock
Oct 21, 2018Follower
Dual LAN connectivity
I am looking into getting the ReadyNAS 422 to store media files and some documents. My issue is I have 2 computers that are on LAN 1 that has internet and 2 devices that are on LAN 2 that can not hav...
- Oct 22, 2018
Hi kylepaddock
Welcome to the Community!
VLAN Support has been added since OS 6.6.0. You just need to go to the Network settings and create the VLAN you need for the NIC you will be using.
You can Map Network drives to your computers if you need to get access to it and use it as drives as well.
Hope this helps!
Regards
Marc_V
Oct 22, 2018NETGEAR Employee Retired
Hi kylepaddock
Hope this helps!
Regards
