Sulu
Jul 23, 2011Aspirant
Duo and Ext Enclosure Question
I just upgraded my ReadyNAS Duo with 2TB drives and did a factory reset (firmware 4.1.7). Now that I have the drives working, I need to purchase a new USB backup drive. Instead of the normal "all in o...
Sulu
Jul 29, 2011Aspirant
Well, after a week of no replies, and 4 days of no help from my Netgear support ticket I guess I have to buy and try. It seems odd that Netgear points you to this thread for "officially" supported external backup drives yet has no support personnel to answer questions here. Not only that but submitting an official support ticket also goes unanswered. Pretty disappointing when I am just looking for a little advice, a "Watch out for that" or "You should be ok".
Anyway the deals on my enclosure and hd will be over soon so I guess I have to be the guinea pig. Here is what I plan to purchase:
Seagate Barracuda XT ST32000641AS 2TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Rosewill RX-358 V2 BLK (Black) 3.5" SATA to USB & eSATA Ext. Enclosure w/Int.80mm fan
