Marq1
Dec 24, 2014Aspirant
Duo dead? Troubleshooting help, pls
Hi all, my ReadyNAS Duo (RND 2150) died last night. At least it was shut down this morning and won't do anything when pushing the power button. I replaced the power adapter but still there's nothin...
Dec 24, 2014Guru - Experienced User
There are some fuses soldered onto the system board, but they are not user-replaceable. I see a reference to a fuse in the plug here: viewtopic.php?f=64&t=73042 Not sure if that applies to all geographies.
Do you have data you need to extract from the hard drives?
