Marq1
Dec 24, 2014Aspirant
Duo dead? Troubleshooting help, pls
Hi all, my ReadyNAS Duo (RND 2150) died last night. At least it was shut down this morning and won't do anything when pushing the power button. I replaced the power adapter but still there's nothin...
Marq1
Stephen,
thanks for your answer! Problem solved the easy way. It turns out not only the Netgear power supply was faulty, but the next I tried as well. I dug up a third one that can act as a temporary solution (12V/3A instead of 5A) for now and ordered a decent one already.
Thanks again,
Marq
Thanks again,
Marq
