Krusher
Dec 19, 2008Aspirant
Duo->NV->Pro upgrade path
From what I've seen in the FAQ, the ReadyNAS Duo can be upgraded easily to the NV+ by simply moving the disks. Can the NV+ be upgraded to the Pro by transferring the disks as well? I realize that ...
Krusher
chirpa wrote: You can move the Duo to the NV/NV+ yes.
But you cannot migrate to the from that platform to the Pro. viewtopic.php?p=123093#p123093
Ok thanks! I missed that in my searching.
