Krusher
Dec 19, 2008Aspirant
Duo->NV->Pro upgrade path
From what I've seen in the FAQ, the ReadyNAS Duo can be upgraded easily to the NV+ by simply moving the disks. Can the NV+ be upgraded to the Pro by transferring the disks as well? I realize that ...
panayis
Jul 19, 2011Aspirant
I have an NV+ system with a lot of users, groups, shares and security set up.
When migrating to a new Pro 6 system can I use the Config Backup from the NV+ and restore it to the Pro 6?
I could then migrate the data from the shares.
Can I do this? Is the config backup compatible between the NV+ and the Pro 6?
No-one has suggested doing this as far as I can find.. it has always been a case of recreating the configuration manually!
