drazic19
Dec 28, 2011Aspirant
Duo v1 or v2?
Hi, Sorry for the newbie question. I just bought a Duo off Amazon and am wondering if it's a v1 or v2? Is there an easy way to find out? Obviously hoping it's a v2 as I wouldn't want to have bought...
drazic19
Dec 29, 2011Aspirant
Thanks for that.
I'm in the UK so the model number I bought was RND2000-100UKS - v1 unfortunately. I'll return this and make sure to get a v2 model. I've found one with the model number RND2000-200EUS. I presume this is a European version or have that got rid of the UK version and gone for EU? Can anyone recommend a retailer to get a v2 from?
I also have loaded up the HDD I bought separately with data. Is it possible to take this HDD used on the v1 device and put it straight in the v2 without data loss?
Thanks again.
Thanks again.
