drazic19
Dec 28, 2011Aspirant
Duo v1 or v2?
Hi, Sorry for the newbie question. I just bought a Duo off Amazon and am wondering if it's a v1 or v2? Is there an easy way to find out? Obviously hoping it's a v2 as I wouldn't want to have bought...
mdgm-ntgr
Dec 29, 2011NETGEAR Employee Retired
The EUS would be a European version. The region identifier basically indicates the language of included documentation, power plugs for a region etc.
No. See last sentence of http://www.readynas.com/kb/faq/boot/how_do_i_migrate_disks_over_from_an_existing_readynas_to_another
If you want to reuse the disk in the v2, you'll need to e.g. do a factory default (http://www.readynas.com/kb/faq/boot/how_do_i_use_the_boot_menu)
drazic19 wrote:
I also have loaded up the HDD I bought separately with data. Is it possible to take this HDD used on the v1 device and put it straight in the v2 without data loss?
