drazic19
Dec 28, 2011Aspirant
Duo v1 or v2?
Hi, Sorry for the newbie question. I just bought a Duo off Amazon and am wondering if it's a v1 or v2? Is there an easy way to find out? Obviously hoping it's a v2 as I wouldn't want to have bought...
PapaBear1
Dec 30, 2011Apprentice
After backing up your data of course, unless it still resides on other devices as the factory default will wipe all data.
I looked at Amazon.co.uk and they listed 15 different vendors that could supply the RND2000-200EUS. On one of the listing it commented that only the 2 pin plug was available. I don't know if this is a European continent only standard, or if the UK also uses the 2 pin plug. Most of the sites mention that the unit would be dispatched from England, but at least one is dispatched from Germany.
Doing an internet search for RND2000-200UKS I get 0 results, but searching RND2000-200EUS I get several thousand. From that I would assume that there is no -200UKS model. (RND2000-100UKS returned over 6,000 results).
