drazic19
Dec 28, 2011Aspirant
Duo v1 or v2?
Hi, Sorry for the newbie question. I just bought a Duo off Amazon and am wondering if it's a v1 or v2? Is there an easy way to find out? Obviously hoping it's a v2 as I wouldn't want to have bought...
hidetora
Jan 19, 2012Aspirant
tim_hamblin wrote: I've just bought the Duo v2 from Amazon UK from one of the marketplace traders... Yes it does have the RND2000-200EUS model number... The trader did supply a 2-pin Euro plug to UK 3-pin plug adapter in the packaging. However, inside the sealed Netgear box, along with the PSU was a UK kettle power lead as well as a Euro one... So it appears that Netgear might be only using one SKU for the EU which includes the UK?
I've just bought the DUO v2 also, bit of a newbie with ReadyNAS so thought id start of with a more straightforward model. Originally made mistake with model codes, eventually realised the codes are more than just 'RND2000', thankfully Amazon kindly refunded me. So now I have the RND2000-200EUS version from Pixmania UK (reasonably cheaper than traders on Amazon UK), they sent an 3pin adapter too but like Tim I found a UK kettle power lead in the box too, so it does seem to me like Netgear are shipping the 200EUS version to all of Europe with both power lead versions in them, certainly saves them having to package up a different box specifically for the UK, perhaps a cost saving exercise(?).
