Mothman1
Feb 11, 2013Tutor
Duo (v1) with WD20EARS + WD20EARX
I have recently swapped out 2 x 500GB drives and replaced with 2 x 2TB drives as per subject line. I have the opportunity to replace the EARS drive with a EARX drive so that they would be a matched ...
mdgm-ntgr
Feb 11, 2013NETGEAR Employee Retired
If you download your logs (Status > Logs > Download all logs) and extract the zip contents what does partition.log look like?
