sherazade's avatar
sherazade
Mix WD20EARS with WD20EARX
Hi,
some month ago I installed 4 WD20EARS into my NV+. After 2 weeks the SMART-stats for an HDD got really bad and I decided to replace the drive with a new replacement drive I ordered as a backup for these kind of situations. I requested an RMA from WD and got my drive replaced with a new WD20EARS.
A few days ago a second drive showed bad SMART-stats (only two defective Samsung drives in 5 years and 2 defective WD-HDDs after 2 month :roll: ) and again I requested an RMA from WD. But this time WD didn't provide a new WD20EARS but a WD20EARX-00PASB0 as replacement.
Now I'm concerned about the compatibility of these drives as it isn't mentioned in the compatibility list. And I'm concerned whether I can mix the new WD20EARX with the old WD20EARS drives. Can anyone tell, if I have to expect issues with this combination?
Best regards
  • I have upgrade my NV+ with a WD20EARX to expand storage to 4G, nothing bad happens till now.
  • Thanks for your reply.
    Meanwhile I contacted WD again and explained to them that I need to have the same model as a replacement drive as I originally bought. It took some time but finally they sent me a new WD20EARS and I returned the WD20EARX.
    Hopefully the WD20EARS are not as bad as their reputation...
    Best regards
    Best regards
    The very reason is that WD20EARS has been out of production for several months....
ProSupport for Business
