sherazade
Aug 25, 2011Aspirant
Mix WD20EARS with WD20EARX
Hi, some month ago I installed 4 WD20EARS into my NV+. After 2 weeks the SMART-stats for an HDD got really bad and I decided to replace the drive with a new replacement drive I ordered as a backup ...
sherazade
Oct 16, 2011Aspirant
Thanks for your reply.
Meanwhile I contacted WD again and explained to them that I need to have the same model as a replacement drive as I originally bought. It took some time but finally they sent me a new WD20EARS and I returned the WD20EARX.
Hopefully the WD20EARS are not as bad as their reputation...
Best regards
Best regards
