Furti
Aug 16, 2012Aspirant
DUO V2: after scheduled power on, usb don't work #19235128
Hello, I bought last week a DUO v2. After activating scheduled power off and on, the two usb ports on backside don't work after on. I must plug off the power cable to made it work again :-( Two e...
evan2
Aug 16, 2012NETGEAR Expert
Which RAIDiator is on your Duo v2?
I tried on my Duo v2 these two days, I can not reproduce the issue, USB disk worked normally after schedule power on, my USB drivers are WD USB2.0 500GB WDBABV5000ABK-00 and WD USB3.0 500GB WDBACY5000ABK-00.
Could you download logs in UI? then send
Thanks!
