Furti
Aug 16, 2012Aspirant
DUO V2: after scheduled power on, usb don't work #19235128
Hello, I bought last week a DUO v2. After activating scheduled power off and on, the two usb ports on backside don't work after on. I must plug off the power cable to made it work again :-( Two e...
evan2
Aug 17, 2012NETGEAR Expert
I checked your logs, system detect USB device when Duo v2 power on,
A few minutes later, it is disconnect and detect again, did you hot plug USB driver a time?
Aug 15 08:44:30 Serien1 kernel: scsi 2:0:0:0: Direct-Access WD 10EADS External 1.75 PQ: 0 ANSI: 4
Aug 15 08:44:30 Serien1 kernel: sd 2:0:0:0: Attached scsi generic sg2 type 0
Aug 15 08:44:30 Serien1 kernel: sd 2:0:0:0: [sdc] 1953525168 512-byte logical blocks: (1.00 TB/931 GiB)
Aug 15 08:44:30 Serien1 kernel: sd 2:0:0:0: [sdc] Write Protect is off
Aug 15 08:44:30 Serien1 kernel: sd 2:0:0:0: [sdc] Mode Sense: 23 00 00 00
Aug 15 08:44:30 Serien1 kernel: sd 2:0:0:0: [sdc] Assuming drive cache: write through
Aug 15 08:44:30 Serien1 kernel: sdc: sdc1
Aug 15 08:44:30 Serien1 kernel: sd 2:0:0:0: [sdc] Attached SCSI disk
Aug 15 08:53:43 Serien1 kernel: usb 1-1: USB disconnect, device number 2
Aug 15 08:53:57 Serien1 kernel: usb 1-1: new high speed USB device number 3 using ehci_marvell
Aug 15 08:53:57 Serien1 kernel: scsi3 : usb-storage 1-1:1.0
Aug 15 08:53:58 Serien1 kernel: scsi 3:0:0:0: Direct-Access WD 10EACS External 1.75 PQ: 0 ANSI: 4
Aug 15 08:53:58 Serien1 kernel: sd 3:0:0:0: [sdc] 1953525168 512-byte logical blocks: (1.00 TB/931 GiB)
Aug 15 08:53:58 Serien1 kernel: sd 3:0:0:0: [sdc] Write Protect is off
Aug 15 08:53:58 Serien1 kernel: sd 3:0:0:0: [sdc] Mode Sense: 23 00 00 00
Aug 15 08:53:58 Serien1 kernel: sd 3:0:0:0: [sdc] Assuming drive cache: write through
Aug 15 08:53:58 Serien1 kernel: sd 3:0:0:0: Attached scsi generic sg2 type 0
Aug 15 08:53:58 Serien1 kernel: sdc: sdc1
Aug 15 08:53:58 Serien1 kernel: sd 3:0:0:0: [sdc] Attached SCSI disk
Aug 15 08:54:02 Serien1 kernel: tntfs info: NTFS volume version 3.1 (cluster_size 4096, PAGE_CACHE_SIZE 4096)
