willp2003
Sep 13, 2012Aspirant
Duo V2 to NV+ upgrade
Hi, I have a Duo v2 which is quickly running out of space (2x2TB drives). I know I can upgrade to 3TB drives, but I was looking at getting an NV+ v2, so it gives me a lot more room for expansion. ...
mdgm-ntgr
Sep 13, 2012NETGEAR Employee Retired
You could follow the procedure here to migrate: http://www.readynas.com/kb/faq/boot/how_do_i_migrate_disks_over_from_an_existing_readynas_to_another
Do make sure both are v1 or both are v2: http://www.rnasguide.com/2012/01/09/how-to-tell-whether-i-have-a-duo-v1-or-duo-v2-or-nv-v1-or-nv-v2/
