willp2003
Sep 13, 2012Aspirant
Duo V2 to NV+ upgrade
Hi, I have a Duo v2 which is quickly running out of space (2x2TB drives). I know I can upgrade to 3TB drives, but I was looking at getting an NV+ v2, so it gives me a lot more room for expansion. ...
Sep 13, 2012Guru - Experienced User
There's room for more than one approach; the important thing is to consider the impact of losing all your data, and being intentional about what you back up (and what you choose not to back up).
PapaBear wrote: If a lot of your data volume is in videos (they really eat the space) and they are not that critical (not family movies for example), then you only concentrate on the critical/important data. For example, while I have a 2.5TB data volume, only about 70GB of mine falls into that category. Personal financial records and photos that are not replicated elsewhere (except in my backups). In addition the NAS to NAS backup of all my shares, only the shares with critical/important data is then also backed up onto a WD passport and stored offsite. I do this periodically, but usually at least once a month. This is my fallback if a disaster befalls the house and wipes out my NAS units as well. (Fire, theft, natural disaster).
Though almost all of my video and audio collection is not really "critical", it still would not be practical to replace it all if it were lost - especially if a disaster damaged the house. Plus I figure that there are some truly critical files that have been parked in the "wrong" folders.
So my backup plan covers my PCs and the entire NAS. That's about 6 TiB at the moment. My disaster recovery relies on the cloud (Crashplan backup), I also maintain local backups.
Disk images of my desktop C drives are backed up to the Pro every week (automatically). The laptops are also done weekly, but manually. Backups from my Pro (which is the main repository) to my older NV+ and Duo are daily and automatic, and Crashplan is continuous/automatic. I also manually run robocopy scripts periodically to copy the Pro repository to auxiliary hard drives in the desktops. The net is that I have two local backups of everything, plus the copy in the Crashplan cloud. If Crashplan continues to work out, I might drop to one local backup copy in the future.
