Ruben_Rocha's avatar
Ruben_Rocha
Duplictate login with win 10 using file manager with rn-316
I have created a couple of home accounts for the different clients I have.
I was going to use them just for backups from desktops/laptops.
I can access and create them with ftp.
However I can't access them using one computer for all accounts.
I keep getting the error that it does not support multiple account logins.
How do I logoff with win10 in file manager so I can login to another home folder.?
  • StephenB's avatar
    As you perhaps know, this is a windows restriction for SMB access, and not an issue in the NAS.
    One thing you can do is run CMD and enter net use * /delete
    One trick here is that Windows treats the hostname and the IP address as different machines, so if you access by IP address you can use a different credential without disrupting an existing connection that uses hostname.
    • Ruben_Rocha's avatar
      Ruben_Rocha
      When you say cmd!
      Do you mean run command.com from the desktop?
        Ruben_Rocha
        I ran it from the command line in the desktop.
        It states no users in the list.
        The name of the nas is readynas
        The home folder is HOMEBOY3
        I have tried selecting the icon in file manager and I have tried typing it as \\readynas\HOMEBOY3
        I get a prompt to login which I do, But I still get not accessible.,Multiple connections not allowed.
ProSupport for Business
