mhellstrand
Mar 14, 2017Tutor
Echange ReadyNAS Duo v2 to new NAS
Hi I have a ready nas duo v2 running at home with 2 3tb mirrored disks. I wonder if I want to "upgrade" to newer (maybe bigger) model of Netgear NAS can I choose a new NAS and have my disks s...
- Mar 16, 2017
Well the solution I am seeing but it is hairy and a bit dangerous is:
setp 0 old device raid 1 redundant new device empty
step 1 old device raid 1 degraded 1 slot empty new device 1 slot populated
step 2 manual data transfer
step 3 old device remaining HDD removal and low level format and insertion (mandatory if you want a clean install) in 2nd slot of new device and adding parity to have raid 1 at least.
end of procedure.
Reagards.
Open to suggestions.
aalexandrebeta
Mar 15, 2017Master
I will ask you a question, WHAT IS THE MONEY you are willing to spend?
My options I'll give you will all depends on that!
What you really want to do in the future, 2/4/6 bays and your future needs.
HOW many GB are you adding each years?
Regards.
mhellstrand
Mar 15, 2017Tutor
Thats not really an answer to my question.
my only concern is "Can I swap my current disks to another NAS unit or not and still keep the data on them?"
Why i'm asking is because i had a ready nas duo version 1 for many years and the hardware broke. Something in the NAS just died but both disks was ok. So in the event that the actual NAS breaksdown and wount reboot any more. How can I save the data on det disks if I cvan't swap them into another newer NAS unit.
//M
- aalexandrebetaMar 16, 2017Master
end of procedure.
Reagards.
Thanks for the kudo but does the procedure I am giving you suits you and answer your question?
Regards!
By the way a solution to lower a bit your stress would be to purchase an extra 3Tb in order to have a permanent redundancy.
NEW procedure if it's a 4 drives solution
step 1 old device raid 1 new device empty slot inserted with new HDD
step 3 old device first HDD removal low level format (mandatory if you want a clean install) and insertion in the second slot new device array building
step 4 old device remaining HDD removal and low level format and insertion in 3rd slot of new device and adding parity to have raid 5 at least
end procedure
