Icauto
Mar 21, 2019Aspirant
Email alert Not going to work with GMAIL effective 3-31-2019
I use GMAIL for my email and the email alerts from my ReadyNAS 214. I received the following email from GMAIL:
Hello,
Although you don’t need to take any action, we wanted to let you know...
Mar 21, 2019Guru - Experienced User
I don't understand the title of your post, as it seems unrelated to the text. Can you clarify?
I also use gmail for notifications, and I haven't seen any email like yours from google. What firmware is your NAS running?
- mopgcwMar 24, 2019Aspirant
I received the same notifications as well; running 6.95.- StephenBMar 25, 2019Guru - Experienced User
mopgcw wrote:
I received the same notifications as well; running 6.95.I believe it depends on whether your email alerts are using token auth or not (my setup isn't using token auth).
Try signing out and then sign in again.
- IcautoMar 25, 2019Aspirant
What do you mean sign in and out again? Sign in and out of the ReadyNAS? I have done that more than once. Are you saying, uncheck the box for the email account info?
